98 blazer Ltwilliam godwin 11-28-2005, 02:27 PM stalling if i sit at idle to long and when iwas driving on the highway at 70 mph it kept bogging down .but was fine at under 50 mph.some times i get a strong fuel smell . Cailen 11-28-2005, 02:34 PM search for cpi check fuel pressure billibong 11-28-2005, 03:16 PM Probably your nut kit or fuel regulator. Search in the forum for CPI or Nut Kit replacement. BlazerLT 11-28-2005, 03:33 PM Guys, this is a 1998, it doesn't have a nut kit or a cpi injector. William, how long ago did you replace the fuel filter or do a tuneup? wolfox 11-28-2005, 03:47 PM Indeed, there is no CPI in a 98. The Gasoline smell could be bought on by a missfire, dumping raw fuel down the exhaust. I am with BlazerLT on this one, do your basic, complete tune-up, all new air and fuel filters - stick to OEM GM AC/Delco parts for your wires, cap rotor and plugs, and see what happens. :) Do it soon too - it probably will not be too much longer before the catalyst and/or an O2 sensor shows problems from the heavy fuel enrichment. billibong 11-28-2005, 03:48 PM Sorry, read the year wrong :uhoh: wolfox 11-28-2005, 03:57 PM Sorry, read the year wrong :uhoh: S'O.K. - we all have off days. I am having one now. First day back o nthe job after a very lazy 4 day weekend. Man, I don't want to do jack. ;) Cailen 11-28-2005, 04:45 PM Glad someone has their head screwed on tight today. william godwin 11-29-2005, 04:06 AM thanks for the info guys ijust changed the fuel filter iwas going to check spark plugs next. idid atuneup awhile ago probably needs it done. thanks again. bill mike2004tct 11-29-2005, 07:29 AM thanks for the info guys ijust changed the fuel filter iwas going to check spark plugs next. idid atuneup awhile ago probably needs it done. thanks again. bill Could also be a plugged EGR valve is if you get on/off surges with gas pedal at steady pressure. BlazerLT 11-29-2005, 11:17 AM thanks for the info guys ijust changed the fuel filter iwas going to check spark plugs next. idid atuneup awhile ago probably needs it done. thanks again. bill What do you usually change when you do a tuneup? vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
