'91 Gtp 3.4 Still Won't Start...help!!!!!jrodz 11-28-2005, 09:01 AM My car died while driving it almost 2 months ago. Fuel pressure ok, fuses ok. I have replaced the battery, stater, coils and module, spark plugs and wires, cranckshaft sensor, knock sensor, TPS sensor, and ECM. The engine turns but won't start. I'm in desperate need of help. Does anybody have C-4???? richtazz 11-28-2005, 10:04 AM Have you checked for compression? You may have broken a timing belt or skipped a tooth. jrodz 11-28-2005, 02:04 PM Have you checked for compression? You may have broken a timing belt or skipped a tooth. Timing belt is not broken and no signs of slipage. richtazz 11-28-2005, 02:12 PM bring us back up to speed as to exactly what happened when it quit (example: it started to lose speed, then chugged, then died etc....) so we can narrow down the possible causes. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
