power windows??????24rida 11-27-2005, 10:42 PM wus up board new here!!!!! I have a 03 silverado and I have a ?????? Where is the fuse for the window, my passanger went out it wont go down it just hear the clicking, if that dont work is that actuator* from ebay any good that $50 dollar one thanks any help is apreciated jethro_3 11-27-2005, 10:44 PM If you hear it clicking it is not the fuse. Pull the panel and see if the cable is bound or jumped the track. Just my :2cents: fishlips 11-30-2005, 02:09 PM I have the same problem. It started struggling to go up and down and then quit working. 2003 Silverado 2500HD, passenger front window. Is this hard to replace, dealer wanted like $400 bucks, but after I said no, it worked fine for about 3 weeks and then had trouble again and now quit while about 4 inches down. Glad its not currently raining. Do I need to replace the motor assembly? Any help would be appreciated. BlenderWizard 11-30-2005, 06:27 PM black99silverado 12-04-2005, 06:11 PM http://www.automotiveforums.com/vbulletin/showthread.php?t=478813 ? I had a 99 Camaro that had the same problem and I was told that it was a bad window motor and that it would cost like $400 to replace it. I dont know how hard it is to replace in a silverado but i know the camaro had rivits holding it in place, and the procedure itself was fairly involved. kmschna 12-06-2005, 03:14 PM Easy fix once you get the door panel off. Buy a new or rebuild window motor/regulator of ebay or where ever and replace. I think there or 4 bolts inside hold the frame to the window. Remove, pull out old reg and add new one. One of my easiest fixes yet. don't for get to tape window up in place. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
