Amp Installation
Google
Web AF
eurotech210
11-27-2005, 08:07 PM
Which wire on the factory stereo (2001 Chevy Silverado) harness would I connect the remote wire for an amp to?
HanibalTheCannibal
11-27-2005, 08:11 PM
Welcome to the Forums!!! :smokin:
I used a harness adapter, so I cannot say for sure. It was a Scosch or something like that. I do not want to pull my dash apart ATM. Someone will chime in I am sure and steer you straight>>
rustcal
11-27-2005, 08:59 PM
find a wire on the fuse box that is only on when the key is or splice into the factory power to radio. this way if you shut the truck off the amp turns off when the radio does when you open the door.
01silverado03z400
11-28-2005, 01:31 AM
If your using an in-line converter, like me, you dont have to connect the remote wire. Your amp will turn on wen ur speakers turn on (wen u turn on ur stereo).
jeverett
11-28-2005, 07:56 AM
Unless your adding an aftermarket head unit that has a remote wire, the way stated above is the best and easiest way to do it.
Faze3
11-28-2005, 03:51 PM
http://www.installdr.com
The wiring colors may be a little off. I think mine was green, but I don't recall ATM. Best thing to do is get a meter and check. Even a cheap one will do the trick.
sportin83
11-28-2005, 10:03 PM
it is a green wire next to the orange one. there will be 2 green wires, 1 will be near a light green wire that is a speaker wire. the other dark green will be near a black and orange wire and that will be ACC on the radio can be used for a remote turn on but make sure that it is fused.
Google
Web AF
