92'escort 1.8 gt starts good,idles rough,diescrazydriverz 11-25-2005, 12:36 PM help me out guys. i have a 92' escort gt with a 1.8 engine. it will start up nice. in seconds it will idle really rough and dies. unless i start tapping on the gas to get the rpm to go up... to stay on.once on the road with some peddle, it will run good. can anyone help me out. Thank you. J-walk 11-25-2005, 06:41 PM a lot of people have this problem with there gt chances are it is your vacuum hose or your throttle body to intake gasket some one said that u could spray some WD40 in that area and it will stop temporarily. thats if it is the gasket. if it is the vacuum hose (goes from just after the intake box ti the throttle body) all u have to do is just try to hold the tube and try to push it in to its spot and if that doesnt work try to clean it out maybe there is something restricting the flow. if those dont work u should get your IAC (idle air control) checked out but that is not as common as the other two. crazydriverz 11-25-2005, 10:01 PM thanks j-walker .i'll check into those leads. once i find out the problem, i'll post it. J-walk 11-26-2005, 01:16 AM hey no problem bud crazydriverz 11-28-2005, 11:43 AM well i found out the problem.it was fouled up injecters.it took me awhile. however i got it. thanks to all. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
