Transmission FillKATIER 11-25-2005, 11:13 AM I Have A 2001 Grand Am With A 3400 Engine With An Automatic Transmission. I Can Find Neither A Dip Stick Under The Hood Or Anywhere Under The Hood To Add Transmission Fluid. Where Is The Dip Stick & Transmission Fill ?? BNaylor 11-25-2005, 11:36 AM It doesn't have a dipstick. The red cap on the driver's side of the tranny is where ATF (Dextron-III) is put in. The level is checked by removing an inspection plug located on the passenger side of the tranny on the right transaxle housing. If you jack it up and look underneath it will be adjacent to the engine oil drain plug. The level must be checked with the vehicle level. Checkout link below: http://www.quality-trans.com/faq/faq8.htm#41 vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
