98 Caravan rear pwr windows fuse?
dhilburn
11-24-2005, 04:41 AM
98 grand caravan SE rear power windows won't work from the switch. Switch has power for the side front windows and locks but no rear pwr windows. I powered th e rear windows shut with a remote battery so they do work. Switch seems to not be getting power to the rear windows only.
Is there a fuse or relay that feeds only the line into the rear windows? I have looked at all fuse boxes and I'm stumped. Thanks.
Mrbizness1
11-24-2005, 11:35 PM
I looked at my 98 factory manual, they don't show any fuses for the rear windows, they seem to go through the BCM. You may need to remove the door panel to look at the switches and the wires that go through the a tube from the door into the left front kick panel area.
Sometimes wires break in the area from all the drivers door movements.
dhilburn
12-24-2005, 07:08 AM
Did not take door apart yet, but moving around the wiring tube from body to door has one of the motore working now. Also noticed that the plug from wiring to body connection may be cracked and seated uneven. Hopefully working on or replacing this will solve completely. Thanks for the input.
