Radio antenna & XM RadioTom-ADC 11-23-2005, 01:32 PM Have a 2004 Impala and want to install after market XM radio in it, I'd like to install a FM direct connector that hooks into the FM antenna is the connector for the rear window antenna easy to get at and if so were is it? I can see the On Star box is it part of that? Thanks from a newbie! MoNsTeR`ImPaLa 11-23-2005, 04:22 PM Have a 2004 Impala and want to install after market XM radio in it, I'd like to install a FM direct connector that hooks into the FM antenna is the connector for the rear window antenna easy to get at and if so were is it? I can see the On Star box is it part of that? Thanks from a newbie! highly detailed web site impala hq (http://impalahq.com/) look under how to's you need to remove the center console. it's all there would rather you look then ask it might be easier.. Tom-ADC 11-23-2005, 04:52 PM highly detailed web site impala hq (http://impalahq.com/) look under how to's you need to remove the center console. it's all there would rather you look then ask it might be easier.. I was there before I posted, what my question was is there a way to locate the antenna back in the rear window area and if so where. I'm trying to add the FM connector without removing the console or instrument panel trim plate if possible. If not I'll follow the how to's on noted site. Thanks Tom vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
