Sprint/Metro transmission swap?idmetro 11-22-2005, 06:10 PM Second gear syncro in an 86 Sprint headed south, not yet destroyed but just a matter of time. I see lots of 5 speed transmissions out there for 89 and later Geos; will these interchange with the earlier versions? I know the engines have their differences but haven't been able to determine if there are transmission differences as well. DieInterim 11-22-2005, 07:35 PM Second gear syncro in an 86 Sprint headed south, not yet destroyed but just a matter of time. I see lots of 5 speed transmissions out there for 89 and later Geos; will these interchange with the earlier versions? I know the engines have their differences but haven't been able to determine if there are transmission differences as well. You cannot get parts for the older trans. I have been told, and when my first gear failed in my Sprint I too wondered about the newer trans. It stands to reason that it should bolt to the engine easily, but mounts and other oddities could require fabrication. Do it! Blake vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
