94 Grand Cherokee
crzfrog
11-21-2005, 09:14 AM
rolls in park
dksob81
11-21-2005, 08:08 PM
Did you remove your FRONT DRIVESHAFT?
If so that is the cause, you will need to use your E-Brake/Parking Brake.
thackstonns
11-22-2005, 12:08 PM
they did a saftey recall on that take it to a jeep dealer and they will install a pin to correct free of charge.
dksob81
11-22-2005, 01:48 PM
The recall thackstonns is referring to is for an event that if you leave you jeep in park with the engine running on a hill it could slip into reverse.
If you removed your front driveshaft and you have the 249 TC, this is the reason your jeep is rolling.
crzfrog
11-23-2005, 09:13 AM
Pulled cover off found chewed up axle splines on pass side and broken and stripped spider gear same axle shaft thinking about doing a bone yard swap? 500.00 axle assembly
ByronP
11-25-2005, 09:12 AM
You should be able to get a boneyard D30 for way less than $500. Search around local or on the web.
ByronP
