Cavalier No SparkRustyRed 11-20-2005, 08:01 PM Hello, Just replaced an engine in a 93 cavalier. Got it dropped in but didn't have the axels/wheels/brakes etc etc hooked up. Started engine to test it and it was running fine. Got in to check transmission, depressed brake pedal and the engine dies. Now it will not start as it has no spark what so ever. Abs light is on as sensors are unpluged. Engine turns over fine but there is no spark. Disconnect battery for a few min and hooked it up, still no spark. Was running GREAT and died instantly when we hit the brake pedal. any ideas? thanks! jeremy06 11-20-2005, 11:36 PM Hello, Just replaced an engine in a 93 cavalier. Got it dropped in but didn't have the axels/wheels/brakes etc etc hooked up. Started engine to test it and it was running fine. Got in to check transmission, depressed brake pedal and the engine dies. Now it will not start as it has no spark what so ever. Abs light is on as sensors are unpluged. Engine turns over fine but there is no spark. Disconnect battery for a few min and hooked it up, still no spark. Was running GREAT and died instantly when we hit the brake pedal. any ideas? thanks! Vacuum leak.................... colinlesser 11-21-2005, 01:15 PM could be the tps vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
