bypassing heater core
Google
Web AF
racer77
11-19-2005, 08:13 PM
i realy need to know how to bypass my heater core in my 97 grand am. i already plugged off the two hoses that went into the heater core . but it still overheated . i wonder igf i should have connected the two hoses so they can circulate
97grandamld9
11-20-2005, 01:21 AM
yea, i would have connected them.
xeroinfinity
11-20-2005, 09:09 AM
well if you want to bypass the core then you do need to connect the two lines on the engine side, so they can still circulate the coolant properly.
But just because you do this, and if you hav other issues causeing the overheating like a stuck/bad thermostat, it still will overheat. Is that whats happening Now, overheating?
racer77
11-20-2005, 09:19 PM
yeah it was over heating, i have connected them together now i'need to replace the heater core. It doesnt seem to be over heating anymore. Thanks for the help
xeroinfinity
11-20-2005, 10:59 PM
hav fun with the core racer77 .
racer77
11-21-2005, 03:18 PM
yep its over heatin.. but now i connected the lines n its ok now thanks
jjstan897
10-07-2007, 11:00 AM
You definitely need to connect the two hoses together. The cooling system has no bypass route so the fluid needs to circulate through.
xeroinfinity
10-07-2007, 01:51 PM
Welcome to AF jjstan897.
If you signed up just to answer questions,
(in a almost three year old thread) then you better start looking at the dates !!! :disappoin
DO NOT bring up threads older then 3 months !! :grinno:
This is outlined in the Community Participation Guidelines (http://www.automotiveforums.com/vbulletin/guidelines.html),
which you should have read when signing up at Automotive Forums.
If you have a question or need help please post your own thread and someone will help you asap.
This is CLOSED !!
Google
Web AF
