Dummy Lights will not go off, ETC!!!!mike.g 11-19-2005, 12:16 PM I need HELP!!! I have an '86 32e that I am fixing up...evrything is going good except I CANNOT get the Brake light dummy light to go off!! I have changed the bulb, board, everything short of the relay sensor itself!! Any ideas ANYONE??? Also, Anyone know where I can order body accessories from? I can't find the "ground effects", dash, or seats for my car anywhere! The ones on it are worn and warped and I'd like to get some OEM stuff, but I cannot find a retailer! AND I want to get my tach working! It quit while I was overseas and I have no clue where to begin! Someone said something about batteries in the dash, but my service lights and speedo work fine. Thanks for all the help! macalintalr 12-29-2005, 01:46 PM In mine, it was the PCB on the 3rd brake light, it had a cold solder problem on one of the wires. When I resoldered the PCB, the Check light went away as soon as you hit the brake pedal the first time after starting. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
