exhaust
Google
Web AF
GB19545449
11-18-2005, 11:33 PM
How much moisture if any are you to get out of the exhaust! At an
idle in park this is a 3.4.
bigrod118
11-19-2005, 10:35 AM
its not a bad thing for moisture to be in exhaust pipes, its normal from the engine, if you ever notice all cars do that. the only problem is can cause is when you let your car sit after a short drive, becuase your car need to warm up for a while to generate enough heat to make all that mousitre evaporate, if you just take a short drive, all that moisture cant evaporate and it sits in your exhaust pipes and eventually you'll have the bottoms of the ehaust system rusting out becuase all that moiture sitting in there. so always let your car warm up or just make sure your driving far enough, escpecially with winter coming.
Google
Web AF
