97 TA Exhaust Manifold Help!!
forthebro
11-17-2005, 11:58 PM
This weekend i will be replacing the exhaust manifold gasket on my drivers side. Does anyone have any advice or any directions on the best way to do this? Thanks alot!
tuske427
11-18-2005, 10:04 AM
I'd suggest the following:
1- have a good book handy, such as a GM service manual, haynes, etc...
2- If you can, today, tonight, etc. soak the bolts on your exhaust manifold with a good penetrating oil. also the exhaust bolts on the base of the manifold/ head pipe. anything you think you'll have to remove. Give them good coatings, and do it a couple of times. allow it to soak overnight and then hit it again as soon as you wake up tomorrow.
You want to help dissolve any rust/ siezing etc of the bolts so they don't break. If they do, then it becomes a real mess.
try not to drive the car while you're letting the oil soak in.
Other than that, follow the book procedures and you should be fine.
good luck!
good luck!
