1995 JGC- Limitedstudious03 11-17-2005, 10:14 PM Just bought a 1995 JGC Limited v8 5.2 the main issue is it wont shift into the last gear and the engine light is on and the speedometer doesn't work installed a new speed output sensor any other ideas? shows 122k Cam7 11-18-2005, 04:30 AM Since you changed the speed sensor with non results check the wirring from the speed sensor. Many sensor problems are in the wirring. As for the engine light being on - turn the key off-then on -off and on -the Computer should flash the code or codes, count the flashes like 24 41 ect. and post back. studious03 11-18-2005, 08:12 PM will turn the key off then on within the hour studious03 11-19-2005, 01:23 AM the check engine light blinked in this order: 3-6-5-5 jeeperphil 11-19-2005, 10:51 AM the speed sensor has to be aligned or it won't work right. the number of teeth on the gear is marked on it. on the top are sets of numbers at 4 locations. turn it so the proper set for that gear is aligned to the line on the case opening. studious03 11-19-2005, 04:53 PM i will check that out.... dksob81 11-19-2005, 05:14 PM the check engine light blinked in this order: 3-6-5-5 Are you sure the codes were 36 and 55, I do not show a code 36 in the book? You might want to recheck. just pay close attention to the flashes and pauses. Well I had an issue with my Speedometer nto working and it was a loose connection from the PCM to the Instrument Cluster. Check the wiring harness right above the PCM (PCM is located on the passengerside firewall in the engine compartment, right behind the Coolant Overflow Bottle), There is a round harness right above the PCM (computer) with a nut in the center of this connector holding it together, check this nut for looseness, If my memory serves me correctly it should be a T30 torx bit. studious03 11-19-2005, 07:28 PM according to this website: http://www.allpar.com/fix/80s-codes.html Code 36 means: solenoid coil circuit (air switching) Code 55 means: End of codes dksob81 11-20-2005, 10:26 AM according to this website: http://www.allpar.com/fix/80s-codes.html Code 36 means: solenoid coil circuit (air switching) Code 55 means: End of codes Have you rechecked the codes. I do not think that code on ALLPAR pertains to JEEP. I checked both my books and there is no code 36. Have you rechecked you codes? studious03 11-22-2005, 05:40 PM I aligned the speed sensor and now i have no more mechanical problems(speedometer, compass, engine light, transmission not shifting). Thank ALL OF YOU so much! vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
