'94 Q45 Gas smell
bradyb
11-17-2005, 08:23 PM
i noticed it last winter and now that it is getting cold again its gotten worse
any suggestions?
Texasoil
02-18-2006, 01:05 PM
the high pressure fuel line is leaking where it connects to the metal fuel line. Check the ones under the intake manifold at the right rear of the engine--those seem to be most offenders. It seems the metal line contracts (reduced diameter) enough to allow leakage if th eclamp is not tight enough. It's a real PITA to get to these clamp--may have to remove top of intake manifold to accomplish--check to find the leak point first--use inspection mirrors as required on cold start -up
