3 subwoofers into a 2 channel amp
Bej0303
11-17-2005, 09:04 AM
i want to hook up three of the same woofer AW100T audiobahn to a two channel amp A8002T also audiobahn can I hooker two up parallel on one channel and the other on the last channel? Thanks for your help.
SUBWOOFER
AW100T
10” EXCURSION SUBWOOFER
60 oz. Strontium Magnet
Power Handling: 400 watts RMS
Frequency Response: 29Hz - 1kHz
Efficiency: 92.3 dB
PHAT 2” Foam Surround
Non-Pressed, Non-Transfer Paper Cone
KM3’ Coated for Virtually No Cone Distortion
2” 4-Layer ASV Voice Coil
Single 4 Ohm Operation
Mounting Dimensions: Depth; 5” Hole, 9” Diameter, 10 1/4”
MULT-CONNECT Lug Lock Terminals
AMP
Class D Power Amplifier
2 Ohm Stable
RCA (Low Level) and Speaker (High Level) Inputs
RCA Outputs
Mono Output
Input Sensitivity: 200mV ~ 8V
THD: <0.05%
Variable Low-Pass Filter: 40Hz ~ 120Hz
Variable Bass Boost Control @ 45Hz: 0 ~ 18dB
Air Induction Fan Cooled
Optional Accessories: ABR100T (Remote Mount Bass Boost Control Knob)
ADM100T (Remote Mount Digital Volt Meter)
4-Way Protection Circuitry: Thermal, Short Circuit, Overload, DC Offset
SUBWOOFER
AW100T
Efficiency: 92.3 dB
AMP
2 Ohm Stable
RCA Outputs
Mono Output
THD: <0.05%
vinnym86
11-17-2005, 09:35 PM
EDIT: sry, i missed what you said; NO! DONT hook it up like that, u'll fry ur amp!! you're giving a 2ohm stereo stable channel a 2 ohm mono load! its more complicted. if u wanna understand why, read up on www.bcea1.com (http://www.bcea1.com)
this is how its drawn out on my soundstream manual, its also a 2ch amp.
say u have (driver A), (B),and (C), and on ur amp, (Left +), (L-), (Right+), and (R-), a low pass filter/inductor, and a high pass filter/capacitor.
wire (L+) to thru LPF to (A+). wire from (A-) to (R-). wire from (L+) thru HPF to (B+). wire (B-) to (L-). wire from (R+) thru another HPF to (C+). wire from (C-) to (R-).
that looks kinda confusing, but its not. plug and chug. L = left channel, R = right. ur 3 subs, A, B, C.
as for the HPF, LPF, i don't know, maybe someone will say you don't need em, but maybe u do. i'm just giving u what i got on this here manual. hope it helps
