windshield wiper sprayer clogged.sharpx 11-17-2005, 09:32 AM I guess mine are clogged because when I try to spray my windsheild wiper fluid, it just drags the dry wiper blade, no spray! :( and yes, the tank is full of fluid. What are these things called and can I buy new ones or do I have to use a needle or something to unclog my current ones? troy1 11-18-2005, 08:23 AM Make sure the pump is working also. GENTLY blow a very small amount of compressed air into the lines should clear it up. victimizati0n 11-19-2005, 08:20 AM my car did this. all i did was take the hose out, and blow on it, and it worked like a dream. (this wasnt an impala, so im not sure how the system works) but i would assume it would be the same way sharpx 11-22-2005, 12:00 AM Make sure the pump is working also. GENTLY blow a very small amount of compressed air into the lines should clear it up. How do I make sure the pump is working? I'd guess it is, because I hear a little noise like it's trying to spray it. I can't seem to figure out how to take the hoses apart to blow into them. I feel like I'm going to rip the rubber. victimizati0n 11-22-2005, 06:20 PM How do I make sure the pump is working? I'd guess it is, because I hear a little noise like it's trying to spray it. I can't seem to figure out how to take the hoses apart to blow into them. I feel like I'm going to rip the rubber. then it is mostlikely working. the hose chould just pop off. sharpx 11-22-2005, 10:28 PM then it is mostlikely working. the hose chould just pop off. where, though? There are pieces where it's connected all through..from the pump to the wipers. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
