transmission fluidtotallywiredracing 11-16-2005, 10:58 PM how do you check or add transmission fluid to a 2002 bug 2.0 liter with automatic trans? veedubmechanic 11-17-2005, 09:49 PM bring it to the dealer Blackbeetle 11-25-2005, 10:01 PM how do you check or add transmission fluid to a 2002 bug 2.0 liter with automatic trans? The plug on the tranny pan is the level check, undo it and if nothing comes out you need to add fluid. BUT It must be checked at 95 - 113 degrees F and the car must be level. Make sure you select all gears while the car is warming up to circulate the fluid. There is a fill plug with a cover up near the one of the air conditioner lines which you can see from underneath the car on the transaxle. I added fluid (special VW type) by undoing the banjo bolt on the tranny cooler and adding fluid thru the hole the bolt came from (be careful of the o-rings) and also be carefull not to contaminate the fluid with Pentosin (red) anti-freeze. The manual recommends new seals for the level check plug as well I re-used mine (no leaks) Not an easy process and I recommend you find a manual with pictures. unless you like doing this :banghead: The manual recommends a cooking or darkroom thermometer inserted in the level check hole. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
