No heat On 1996 Caravanfissa 11-15-2005, 06:17 PM Hi There I have 1996 Dodge Caravan last year the AC Compressor Seized and I disconnect the clutch cable and have a heating issue I flush the coolant every 2 years this year I flush it but still no heat I replace last year the thermostat and the neck and gasket but still no heat only when I drive for 10 minute i will start to feel some heat but I noticed that one side on the heater core hose is hot and the other side is cold and same for the rad one side is hot and the other is cold change the rad cap and still don't feel there is circulation in the coolant but one thing to mention is I flush the heater core last year but that did not help either pleas if any one had any info thank you DonSor 11-15-2005, 08:42 PM Sounds like you got some restriction in one oor more of your heater hoses. Also check for a stat that is stuck open. 10 minutes is too long for an engine warm up if the stat is working right. cyclonicblade 11-22-2005, 09:30 PM Sounds like you got some restriction in one oor more of your heater hoses. Also check for a stat that is stuck open. 10 minutes is too long for an engine warm up if the stat is working right. I could be wrong but check the vacum lines there also should be a vacum line going to a vale on the heater core lines on the firewall if you can switch heater defrost positions ok the the doors are getting vacum in the dash but the line going to the heater control valve may of come off or the valve may be stuck vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
