time for a new intake manifold!!!
Google
Web AF
cavaliermaniac
11-12-2005, 05:22 PM
i have this really good sight that my friend hooked me up with for racing parts for almost any car but i need a new intake manifold and i have to choose between a j-body w/ EGR or j-body w/o EGR .... my car is a 99, 2.2 j-body .... help me please!
Schister66
11-12-2005, 06:10 PM
so why are you getting a new intake mani? If this is a mod for power, there are a lot better things you can do because an intake manifold isn't really going to help much w/o other mods to support it.
Thor06
11-12-2005, 06:55 PM
My thoughts exactly. A new intake manifold wont do anything unless you are running quite a bit of boost. Unless you have a heavily modified car, I wouldnt bother, just go down to the local junk yard and pick up a stock one.
cavaliermaniac
11-13-2005, 11:20 AM
ok the thing is it is heavy moded... it have new heads, 7 psi supercharger and my dad aka drag racer macanic says that i need to upgrade the flow of fuel into my car for more power and i already odered a new throttle body for it but it doesn't fit the stock intake ... this is why i need to know
Schister66
11-13-2005, 01:16 PM
doesn't your supercharger take the place of the intake manifold? The JRSC designed for my car takes the place of the mani......
and if you're upgrading the amount of fuel into your car, why aren't you doing a fuel system upgrade?
I smell BS...
cavaliermaniac
11-13-2005, 01:52 PM
no the supercharger doesn't replace the manifold... and i am going to be doing that i have a new fuel stuff ordered but the thing is you can upgrade all of that stuff but if you cant get it into the engine fast enough for the engines demand it does nothing other then put preasure on the lines and normally couses leaks... so bigger throttle body to eliminate the leak problem!
Thor06
11-13-2005, 02:04 PM
I smell BS...
:1:
1. If your dad is a "drag racer mecanic" why dont you ask him?
2. A 2.2 has ONE head.
3. You'll need bigger injectors, fuel pump, and fuel controller of some sort before you will need a bigger intake manifold.
What kind of S/C do you have? Lets see a link.
-Jayson-
11-13-2005, 02:17 PM
go to www.jbody.org to find your answer. This forum doesnt know much when it comes to performance. Just rice.
PsychoJJ
11-13-2005, 02:43 PM
No need to be like that, now is there jason?
jakegday
11-13-2005, 11:29 PM
jason does make a good point, after all, no one has been able to actually answer the guys question yet....
PsychoJJ
11-13-2005, 11:55 PM
No one is going to know everything about everything. People are good in some areas and not others or some people are just starting out. That doesnt make anyone less of a person.
Google
Web AF
