can not start only "click" scan test B2960
sn01
11-08-2005, 08:33 PM
dealter checked and the result is :avr test and scan test B2960 set needs passlock cylinder replaced
it is really expensive,so i declined to change.
now the start is no problems. Is it a big problem in the future? could someone give me some advice. i am afraid some day i can not start it again.
Laser17
11-09-2005, 07:14 PM
hey i had the problem today, and it turned out the battery was going bad and didn't have enough power to turn the starter, only enough to make the click. So check that first
maxwedge
11-09-2005, 07:51 PM
If there is an intermitternt open in the key cylinder, it will not start any time it sees fit.
sn01
11-09-2005, 08:09 PM
hi,
thank you so much!
by the way i can not understand "If there is an intermitternt open in the key cylinder, it will not start any time it sees fit"
could you explain to me more detail.
thanks again
