gear ratio
Google
Web AF
andrew85
11-08-2005, 04:57 PM
ok im confused. Now i want ot know how long my rear end is going to last and how muchim going to have to let up on it. So when i was in auto class i looked up on Mitchell On Demand some information and it said that " The Rear Axle identification information is stamped on the forward side of theleft or right axle tube." Now I didnt see shit on either one. Could it meen on the axle housing. If not how else can i figure it out without tearing the fucker apart.
tcfco2005
11-08-2005, 05:13 PM
Let me know all the info on your car..Year, auto or man, engine, rs, z28, and so on and so on....
Savage Messiah
11-09-2005, 02:02 AM
what does your question have to do with gear ratios?
z28 boy
11-09-2005, 02:36 AM
u could just go off the RPO codes, it would be alot faster that way.
Savage Messiah
11-09-2005, 11:24 AM
he speaks the truth.
flatlander757
11-09-2005, 11:47 AM
93-97
Code Description
AG1 Adjuster, 6-Way Power, Driver Seat
AG4 Adjuster, 2-Way Manual, Driver Seat
AH3 Adjuster, 4-Way Manual, Driver Seat
AK5 Restraint System Front Seat, Inflatable, Driver and Passenger
AN4 Restraint Provisions, Child
AQ9 Seat, Passenger and Driver, Recline
AUO Lock Control, Remote Entry
AU3 Lock, Side Door, Electric
A31 Window, Power Operated, Side
A90 Lock, Rear Compartment Lid, Remote Control, Electric
B35 Floor Mats, Rear, Carpeted Insert
B84 Exterior Molding, Body Side
CC1 Roof Hatch, Removable Glass Panels
C41 HVAC System, Heater
C49 Defogger, Rear Window Electric
C60 HVAC System, Air Conditioner, Manual Control
DD9 Mirror, Outside, LH & RH, Remote Control, Electric, Breakaway, Painted
DE4 Sunshade, Removable Hatch Roof
DG7 Mirror, Outside LH & RH, Remote Control, Electric, Painted
DL5 Decal Roadside Service Information
D35 Mirror, Outside LH Remote, RH Manual, Painted
D82 Paint Special
FE2 Suspension system, Ride handling
FE9 Certification Emission, Federal
F41 Suspension System, Firm Ride Handling, Front and Rear
GU2 Axle, Rear 2.73 Ratio
GU4 Axle, Rear 3.08 Ratio
GU5 Axle, Rear 3.23 Ratio
GU6 Axle, Rear 3.42 Ratio
G80 Axle, Rear Posi-traction (Limited Slip)
ILD Trim, Interior Design
IL2 Trim, Interior Design
IPB Trim, Interior Design
IP2 Seat, Leather Sport Front Bucket, Driver & Passenger, Reclining
J41 Brake System, Power, Front Disc, Rear Drum, Cast Iron
J65 Brake System, Power, Front and Rear Disc
KG9 Generator, 140 Amp
K05 Heater, Engine Block
K34 Cruise Control, Automatic Electronic
K68 Generator, 1 05 Amp
LT1 Engine, 5.7L (V8) MFI
L36 Engine, 3.8L (V6) MFI
MM5 Transmission, 5-Speed Manual (Merchandising Option)
MM6 Transmission, Manual, 6-Speed, Borg Warner, 65mm, 2.66 1st, 0.50 6th, O/D
MN6 Transmission - 6-Speed Manual (merchandising Option)
MXO Transmission - Automatic O/D (Merchandising Option)
M30 Transmission - Automatic, 4-Speed, 4LE, Electronic
M49 Transmission, Manual, 5-Speed, Borg Warner, 77mm, 3.75 1st, 0.76 5th, O/D
NB6 Emission System, California Requirements, Tier 1
NC3 Tailpipe Modifications
NF2 Emission System- Federal Requirement, Tier 1
NK3 Steering Wheel, Sport, Soft Rim, Simulated Leather
NP5 Steering Wheel, Leather Wrapped
NW9 ASR Traction Control
N36 Steering Wheel, 4-Spokes, Sport
N60 Wheel, Aluminum, Painted
N92 Cover, Wheel, Bolt-On
N96 Wheel, 16x8, Cast Aluminum
N98 Wheel, Chrome, Var 2
P05 Wheel, Chrome, Var 1
P08 Cover, Wheel, Super Deluxe
QA7 Wheel, 16x7.5, Aluminum
QB3 Wheel, 16x7.5, Steel
QEA Tire, P215/6OR16 BW R/Pe ST TL AL2 94T
QFZ Tire, P24515OZR16 BW R/PE ST TL AL3
QII Tire, P21516OR16 BW R/PE ST TL AL3 94H
QLC Tire, P24515OZR161N BL R/PE ST TL HW4
STE Plant Code-St. Therese, PQ, GM of Canada
TR7 Headlamps, Automatic Control Leveling System
T39 Lamp Turn Signal, Auxiliary
T43 Spoiler, Rear
T61 Lighting- Daytime Running
T96 Lamp, Fog
UA6 Theft Deterrent System
UB3 Instrument Cluster, Oil, Coolant, Temperature, Volts, Trip Odometer, Tachometer
UK2 Lever, Directional Signal, Multifunction
UK3 Electronic System Accessory Control
UL0 AM/FM Cassette ETR 200 Watt Monsoon Sound System w/cassette
UN0 AM/FM Cassette ETR 200 Watt Monsoon Sound System w/CD player
UN6 Radio, AM/FM stereo, Seek/Scan, Auto Reverse Music Search Cassette, Clock, ETR
UQ0 Speaker System 4, Dual Front Door Mounted, Standard Range Quarter/Shelf
UU8 Radio, AM/FM Stereo, Seek/Scan, Auto Reverse Music Search Cassette, HPS, Clock, ETR
U1C Radio, AM/FM Stereo, Seek/scan, Compact Disc, Clock, ETR
U1S 12 Disc Compact Disc Changer
U1T Radio, AM/FM Stereo, Seek/Scan, Compact Disc, HPS, Clock, ETR
U18 Speedometer Instrument Kilometers
U19 Speedometer Instrument, Kilometers and Miles, Kilometer Odometer
U62 Speaker system 4, Dual Coax Front, Dual Coaxial Package shelf
U65 Speaker system 5, Dual Front Door Mtd, Dual Ext. Range Panel, Single Rear Compartment
U73 Antenna, Fixed
U75 Antenna, Power
VG8 Label, Vehicle, Notice to Buyer
VH5 Plate, Vehicle Information
VK3 License Plate, Front Mount Package
VP6 Noise Control
WS6 Performance Package - Formula/Trans Am
WU8 SS Performance Package/Appearance Package - Camaro
W51 Entertainment system - Radio, AM/FM-stereo, seek/scan, cassette, 4 Speaker system · Standard Range
W52 Entertainment System - Radio, AM/FM stereo, Cassette, Equalizer, 4 Speaker system - Coaxial
W53 Entertainment System - Radio, AM/FM Stereo, Compact Disc, Equalizer 4 Speaker System - Coaxial
W54 Entertainment System - Radio, AM/FM Stereo, Cassette, Equalizer, 10 Speaker System, Amplifier
W55 Entertainment System - Radio, AM/FM Stereo, Compact Disc, Equalizer 10 Speaker System, Amplifier
W57 Entertainment system - Radio, AM/FM stereo, Cassette, Equalizer, 4 Speaker system - Coaxial
W58 Entertainment system - Radio, AM/FM Stereo, Compact Disc, Equalizer, 4 Speaker system - Coaxial
W59 Entertainment system - Radio, AM/FM Stereo, Cassette, Equalizer, 6 Speaker System, Dual Front Door Tweeters/Woofers, Extended Range Shelf
W66 Merchandised Package - Formula
W73 Entertainment system - Radio, AM/FM Stereo, Compact Disc, Equalizer, 6 Speaker system, Dual Front Door Tweeters/Woofers, Extended Range Shelf
Y81 Merchandised Package - Firebird
Y82 Merchandised Package - Trans Am, Base Coupe
Y84 Merchandised Package - Trans Am
Y87 Merchandised Package - Performance Enhancement
Z28 Merchandised Package - Special Performance
Z49 Canadian Modifications
01U Primary Color exterior, Special
05Q Molding Color, Cyclamen
O5U Primary Color Exterior, Cyclamen
1LE Performance Package Components
101 Interior Trim - Arctic White
1OT Top Color - Arctic White
102 Trim Combination Leather, Arctic White
1OQ Molding Color - Arctic White
1OU Primary Color - Exterior, Arctic White
12B Trim Combination - Cloth, Graphite
12D Trim Combination - Cloth, Graphite
121 Interior Trim - Graphite
14B Trim Combination - Cloth, Dark Gray
1SG Preferred Equipment Group
28U Primary Color - Exterior, Navy Blue Metallic
1FP87- Camaro Coupe Z28
flatlander757
11-09-2005, 11:51 AM
98-02
AG1 - Power Adjuster, Driver Front Seat, Multi-Directional
AK5 - Inflatable Restraint System, Driver and Passenger Seat
AQ9 - Front Bucket Seat, Driver and Passenger Recline
AR9 - Front Bucket Seat, Driver and Passenger Recline, European Style
AU0 - Remote Entry Lock Control
AU3 - Side Door Electric Lock Control
AX4 - Restraint Conversion Seat, Manual European
A26 - Window Glazing, European
A31 - Window, Power Operated, All Doors
A90 - Lock Control, Right Component Lid, Remote Control Electronic Release
BAG - Parts Package Export
BBS - Knob Shifter Hurst
B35 - Covering Rear Floor Mats
B9W - Wiring Provisions, DRL Override
CC1 - Roof Hatch Removable Panels, Glass
C49 - Rear Window Defogger, Electric
C60 - HVAC System AC Manual Controls, Front
DD9 - Mirror, Breakaway, O/S LH & RH Remote Control Electric Color
DE4 - Sunshade, Removable Hatch Roof
DG7 - Mirror, O/S LH & RH Remote Control Electric Color
DL5 - Decal, Roadside Service Information
DS1 - Sales, Diplomatic
D21 - Sunshade, Windshield
D35 - Mirror, O/S LH Remote Control, RH Manual Control, Color
ETA - Harness, I/P Wiring #1
FE2 - Suspension System, Ride and Handling
FE4 - Suspension System, Special Ride and Handling
FE9 - Certification, Federal Emission
FLT - Fleet Processing Option
F41 - Suspension System, Front and Rear Firm Ride and Handling
GU2 - Axle Ratio 2.73, Rear
GU4 - Axle Ratio 3.08, Rear
GU5 - Axle Ratio 3.23, Rear
GU6 - Axle Ratio 3.42, Rear
G80 - Axle Positraction, Limited Slip
JAF - Brake Provisions, European
J65 - Brake System, Power, Front and Rear Disc
K05 - Heater, Engine Block
K29 - Module Powertrain Control
K34 - Cruise Control, Automatic, Electronic
K43 - Generator, 102 Amp
K68 - Generator, 105 Amp
LS1 - Engine, Gas V8 5.7L SFI Aluminum
L36 - Engine, Gas V6 3.8L MFI HO
MAE - Marketing Area Europe
MM5 - Merchandised Transmission, Manual 5 Speed
MM6 - Transmission, Manual 6 Speed O/D
MN6 - Merchandised Transmission, Manual 6 Speed
MX0 - Merchandised Transmission, Automatic O/D
M30 - Transmission, Auto 4 Speed Electronic
M49 - Transmission, Manual 5 Speed O/D
NA3 - Emission System, Japan
NC1 - Emission System, California
NF7 - Emission System, Federal
NK3 - Steering Wheel, Sport, Soft Rim, Simulated Leather
NM2 - Emission System Export, Leaded Fuel
NP5 - Steering Wheel, Leather Wrapped
NP7 - Steering Column, EEC Approved
NT3 - Emission System, EEC 00
NW9 - Traction Control, Electronic
N36 - Steering Wheel, 4 Spoke Sport
N60 - Wheel, Aluminum, Painted
N66 - Wheel, Styled Aluminum
N73 - Wheel, Custom Sport Var4 17"
N92 - Cover, Wheel, Bolt-on
N96 - Wheel, 16 X 8 Cast Aluminum
N98 - Wheel, 16 X 8 Cast Aluminum Chrome
PA6 - Wheel, Styled Painted
PW7 - Wheel, 16 X 8 Aluminum Styled
P05 - Wheel, Chrome
QB3 - Wheel, 16 X 7.5 Steel
QCB - Tire, All P235/55R16-96T BW AL2
QEA - Tire, All P215/60R16-94T BW AL2
QFK - Tire, All P275/40R17-93W BW HW4
QFZ - Tire, All P245/50R16 BWAL3
QF6 - Wheel 17 X 9, Aluminum
QII - Tire, All P215/60R16-94H BW AL3
QLC - Tire, All P245/50R16/N BL HW4
TR7 - Headlamps, Control Leveling System, Automatic
T2H - Ornamentation Exterior, Export Unique Requirements
T2J - Ornamentation Interior, Export Unique Requirements
T37 - Lamp, Fog, Deluxe
T39 - Lamp, Turn Signal, Auxiliary
T43 - Spoiler, Rear
T65 - Lamp System, Daytime Running, Export
T72 - Headlamps, LH, Rule of the Road
T78 - Headlamp Control, Delete
T79 - Lamp, Fog Rear
T82 - Headlamp Control, Automatic ON-OFF
T84 - Headlamps, RH Rule of the Road
T85 - Headlamps, LH Rule of the Road
T89 - Lamp, Tail & Stop, Export
T90 - Lamp, Signaling and Marker, Export
T96 - Lamp, Fog
UA6 - Theft Deterrent System
UB3 - Cluster, Instrument, Oil Cool Temp Volts Trip Odom Tach
UC2 - Speedometer, Instrument, Kilo & Miles, Positive Bias
UD4 - Alarm, Vehicle Speed, 120 K/H
UK1 - Frequencies, Japanese
UK2 - Lever, Directional Signal, Includes Multi-Functions
UK3 - Control, Steering Wheel, Accessory
UL0 - Radio, AM/FM Stereo Seek/Scan Auto Rev Music Search Cass Auto-Tone Clock ETR
UL2 - Frequencies, European
UL8 - Frequencies, Saudi Arabian
UM6 - Radio, AM/FM Stereo Seek/Scan Auto Rev Cass Clock ETR
UN0 - Radio, AM/FM Stereo Seek/Scan Compact Disc Auto Tone Clock ETR
UQ0 - Speaker System, 4 Dual Front Door Mounted, Dual STD RGE, Qtr/Shelf
UW3 - Radio, AM/FM Stereo Seek/Scan, Auto Rev Music Search Cass Data System Clock ETR
UZ7 - Speaker System 8, Quad Front Door Mounted, Dual Sail Panel, Dual Rear Hatch Amplifier
U12 - Speedometer, Dual Scale with Kilometer Odometer
U19 - Speedometer, Instrument, Kilo & Miles, Kilo Odometer
U59 - Speaker System 8, Dual Front Door Mounted, Quad Sail Panel, Amplifier
U73 - Antenna, Fixed Radio
U75 - Antenna, Power Radio
VA5 - Language Label, English
VD1 - Provision Options, Europe
VE1 - Provision Options, Japan
VE2 - Protector Source Applied
VG1 - Protector, Underhood Compound, Clear
VG4 - Protector, Undervehicle Compound, Black
VG9 - Protector Wax, Exterior Body
VH5 - Plate Vehicle Identification
VI6 - Fleet Incentive, American Standard
VJ1 - License Plate Rear Mounting Package, Japanese
VK3 - License Plate, Front Mounting Package
VL4 - License Plate, Front Mounting Package, EEC
VL5 - License Plate, Rear Mounting Package, Export
VL6 - License Plate, Front Mounting Package, Japanese
VP6 - Noise Control
VR6 - Hook, Tie-Down, Shipping
VR7 - Hook, Tow, Second, Rear
V12 - Cooling System, Power Steering Fluid
V76 - Hook, Tow
WS6 - Performance Package Special
WX7 - Wiring Provisions
W53 - Entertainment System Option C
W54 - Entertainment System Option D
W55 - Entertainment System Option E
W66 - Merchandised Package, Formula
W68 - Sales Package, Firebird Ground Effects
X10 - Entertainment System, Option L
X20 - Entertainment System, Option M
Y3F - Sales Package, Sport, Appearance Upfitter
Y4A - Exhaust Cat Back
Y4B - Provisions Level II Ultra Performance Suspension
Y4C - Lubricant Engine Oil & Performance
Y4D - Axle Torque Sensing Differential
Y4E - Cooling System Engine Oil
Y4F - Provisions Hurst Shifter
Y4G - Provisions Chrome Wheels
Y4H - Ornamentation Dash Plaque & Key Fobs
Y4J - Covering Floor Front Mats
Y4K - Protector Car Cover
Y4L - Provisions Spoiler
Y81 - Merchandised Package, Firebird
Y82 - Merchandised Package, Firebird, Trans Am
Y84 - Merchandised Package, Firebird Trans Am, GTA
Y87 - Merchandised Package, Performance Enhancement
1R3 - Vehicle Identification Label 1
1R4 - Vehicle Identification Label 2
Taken from jrp on LS1Tech :)
The sticker with all of those codes will be either in the glovebox or on the driver's side door jamb.
andrew85
11-09-2005, 04:17 PM
It had a 2.8L V6, Automatic, it is RS, and its an 85'. Thats pretty much it that I think can help.
Savage Messiah
11-09-2005, 06:19 PM
gonna guess 2.73 but that has no factual basis
flatlander757
11-09-2005, 09:54 PM
Oh, then none of those option codes apply to you :-/
I'll see if I can dig up some 3rd gen RPOs.
edit: Copy down EVERY option code on your RPO sheet and enter them here...
http://www.lonestarthunder.com/rpo/
z28 boy
11-10-2005, 01:47 PM
I think u could to like camarosource.com or something like and u would find the codes for u. I think Geno knows the site.
flatlander757
11-10-2005, 02:42 PM
I have access to a dealer computer so I can find out whatever every RPO code means. Put them into that site I showed you, and if any come up unknown, let me know.
tcfco2005
11-10-2005, 02:47 PM
you have 3.42's according to thirdgen.org....go there and to to tech data...its on the left side and it will have info there.
Google
Web AF
