Doors rattle on a 03
aceads
11-08-2005, 10:52 AM
All of my doors (5) rattle . How do I fix it? Ive been told it is the " latch" .Is this true? or is it in side the doors If so how hard are they to take off...the panels,
Thanks CHRIS
Thanks CHRIS
Ewald
11-08-2005, 01:14 PM
I had the same problem with my previous Expedition, a 2003 model. It are the latches, but don't bother adjusting them... I got hands on the below Ford service message. The dealer ordered the kit (Weatherstrip and latches), installed it, and all rattles where gone. Was done under warranty.
17734 2003 EXPEDITION/NAVIGATOR - RATTLE, RUBBING OR TICKING NOISE FROM DOOR
SOME 2003 EXPEDITION/NAVIGATOR VEHICLES MAY EXHIBIT A RATTLE/RUBBING/TICKING NOISE FROM ONE OR MORE DOORS DUE TO EXCESS MOVEMENT OF DOOR RELATIVE TO THE LATCH STRIKER PLATE. TO VERIFY, DRIVE VEHICLE AND MANUALLY PULL DOOR INBOARD WHILE NOISE IS PRESENT. IF NOISE IS UNCHANGED, SEE TSB 03-23-3. IF NOISE DECREASES, REPLACE THE WEATHERSTRIP AND/OR LATCH AND/OR SHEDLIP ON AFFECTED DOOR(S) AS NEEDED. UNITS BUILT AFTER 05/12/03 CONTAIN REVISED WEATHERSTRIPS; UNITS BUILT AFTER 7/21/03 CONTAIN REVISED LATCHES. DO NOT RESET DOORS - DOOR CLOSING EFFORTS WILL DECREASE IN 2 WEEKS AS SEALS AGE. IF STILL UNRESOLVED, REPLACE SHEDLIP WITH 2004 MY PART. WEATHERSTRIP: 3L1Z-7820708-BA(FRONT); 3L1Z- 78253A10-BA (REAR). LATCH: 4L1Z-78219A64/5-AA (RT/LEFT FRONT); 4L1Z-78264A00/1 -AA (RT/LEFT REAR). SHEDLIP: 4L1Z-7851222-AA (RIGHT); 4L1Z-7851223-AA (LEFT).
Ewald
Expedition Eddie Bauer 2005
Ewald
aceads
11-08-2005, 02:23 PM
Thanks for the info!!! It looks like I might have to buy them myself, Its out of warranty. I might look on the net for a cheaper place than my local Ford dealer
Thanks, Chris
Thanks, Chris
aceads
12-12-2005, 06:12 PM
latches? Sorry for being stupid but do you mean the striker plate on the body or the Latch part of the DOOR? Which one do I buy?. Im going to try and buy them. mine has a build date of 11-03 . when I pull my door in it sounds the same, Plus did they fix the 5th door?
Thanks, for your help
Chris
Chris
Ewald
12-13-2005, 10:11 AM
As far I know they changed the latches and weather-strip of the 4 doors only. The revised weaterstrip had a stronger "spring" action. No adjustments where made to the striker plates. The was no issue with the 5th door / tailgate.
