Car Stereo
Google
Web AF
Caesar84
11-07-2005, 11:30 AM
Im sure many have put new stereo heads and big speakers in there 2005 or similar model Impalas. now who wants to give me some knowledge?
i heard rumors the OEM stereo head had to always be connected to the car for the car to work. true?
please clue me in on any other help tidbits? huhuhuh i said tidbit
MoNsTeR`ImPaLa
11-07-2005, 12:44 PM
the factory stero does not need to stay connected but it is a good idea to buy the relocation cable this allows you to use your stereo to change the security functions and reset to oil change light yada yada ...yeah i said yada yada
Sinkhole
11-07-2005, 08:16 PM
OOOOOO!!!! Relocation Cable !!!! Didn't know one of those exsisted. I just had to take my Alpine out and pop the OEM unit in to reset my Oil Life Light. I definitly Don't wanna do that every time the light pops on. Where can I get one, how much and where does it let you relocate the head unit to.
ncso911
11-08-2005, 09:13 AM
The oil change light can be reset by turning the iginition switch to on, not crank, and the acclerator to the floor three times within 5 seconds.
Sinkhole
11-08-2005, 11:08 AM
Nope didn't work. Tried it about 15-20 times.
MoNsTeR`ImPaLa
11-08-2005, 12:01 PM
most stereo shops will be able to order it just explain what you have and what you want the only one i have seen allows relocation to the trunk well it's long enough to relocate it to the trunk but i'm sure you could put it any where you wanted
MoNsTeR`ImPaLa
11-08-2005, 12:06 PM
um no that wont work and please if you are unsure dont reply or read more first
Sinkhole
11-08-2005, 11:08 PM
Ahhhhh perfect. The trunk is what I want. I have the perfect spot for it.
bermis519
11-08-2005, 11:15 PM
I thought the radio controled the door chime, key fob settings and all the stuff???
Mike
MoNsTeR`ImPaLa
11-09-2005, 08:59 AM
yes all that stuff too bermis
bigrod118
11-09-2005, 03:44 PM
wel the radio doesnt control it, it allows you to change it. all those settings get sent to the BCM and it remembers evrything, so if you go to take out your radio, amke sure you have all your setting where you want them because once you take it out, they will stay how you had them and you cant change them unless you put the stereo back in or relocate it.
MoNsTeR`ImPaLa
11-09-2005, 03:54 PM
when im ready to swap it out im putting it behind the glovebox or in the trunk but hidden bot like some i have seen in other posts
ogre73
11-09-2005, 10:53 PM
http://www.automotiveforums.com/vbulletin/showthread.php?t=351362
Check out the info here. I wish a mod would make one of these damn posts sticky, so that people who forget how to use the search button would at least be able to answer some of their own questions.
Jim
ncso911
11-10-2005, 07:38 AM
MoNsTeR`ImPaLa
Apparently you don't know.
Who said I wasn't sure.
I own two (2) Chevys and it works on them.
MoNsTeR`ImPaLa
11-10-2005, 09:12 AM
MoNsTeR`ImPaLa
this i know BUT it will not work on the impala with RDS it dont work on mine or any other i know of that is reset through the radio
ncso911
11-10-2005, 03:49 PM
As per the owners manual on my 2002 Impala with an RDS radio, and I quote,
"Using the Accelerator Pedal
1. Turn the ignition to ON, with the engine off.
2. Fully press and release the accelerator pedal three
times within five seconds.
If the CHANGE ENGINE OIL message flashes, the
system is reset. However, if it stays on, it did not reset.
You’ll need to repeat the reset procedure."
bigrod118
11-10-2005, 04:40 PM
yeah in my manual for my loaded LS, it tells you how to do it thru the radio, but then it also says if you dont have the type of radio to do it, you can do it the other way. so maybe the pedal way works on any of them. I know many times on other cars ive tried doing pedal tricks for things and I always fucked it up and it took me forever to get it right and to take. so maybe when you tried it it just wasnt in the time frame or didnt press the pedal far enough to hold it there or whatever it may be, but it might have just not took when you tried it?
I would think that the pedal tricks would work on any impala becuase you have to have the pedals to drive your car, so evryone has pedals, so evryone can do those tricks. if that makes sense.
Sinkhole
11-10-2005, 11:03 PM
Funny my owners manual for my 2003 makes no such statement. The only way it refers to reseting the Oil Life Monitor is through the radio. And the gas pedal trick will not work on my car.
Thats why I'm relocating my factory head unit to the trunk.
MoNsTeR`ImPaLa
11-11-2005, 10:22 AM
it dont wrok on mine either and from what a friend says if your car has the radio the pedel funtion is disabled
ncso911
11-12-2005, 09:47 AM
Wrong...
I have two chevy's ('01, '02) with the OEM radio and the easiest way to do it is through the gas pedal...
ogre73
11-12-2005, 12:37 PM
I have a 2003 base with an RDS radio and I got curious as this thread progressed. Since my oil light was on anyway, I decided to try it. It does work on the 2003 imps with RDS.
Jim
Sinkhole
11-13-2005, 11:49 PM
Dude, why don't you drive out to my place in Ct and show me how its done. Cause it sure as hell DOES NOT work on my '03 Impala with RDS. Relocation kit here I come.
Google
Web AF
