tie rod/lower A-arm ball joint removal
randywirtzfeld
11-04-2005, 11:15 PM
Anybody know where to get a ball joint removal tool that will work on a 94 Mirage? The clearance between the threaded end of the ball joint and the cv axle is 3/8" which rules out a lot of the tools, and I don't want to use the pickle fork kind since they destroy the rubber boot?
My Mits. manual of course has the tool number but all the local auto supply stores do not have it.
Gambbitt
05-26-2006, 02:12 AM
Ok, you have to replace all tie rod-lower arm completely. Not the ball joint only. The part is only one. I don't know if you understand me but it is.
