Transaxel Oil Changingpdv1 11-04-2005, 08:44 PM how I Can Change Myself The Transaxel Oil In My Cavalier 1997 ??? And Which Is The Appropiate. Thank You OverAllComa 11-04-2005, 09:53 PM Drop the transmission pan, let it drain, replace the filter, don't lose the magnet. Native language french? MT-2500 11-04-2005, 09:58 PM Drain the old out and put new in. Piece of cake. If you have a Isuzu 76mm 5 speed std. Go to your dealer and get 2 qts of GM Synchromesh trans fluid. GM Part no. 12345349 If you have a real long funnel you can stick it down in the filler hole from the top side. Or reach way down from the top and check fluid level dip stick. MT-2500 greg9034 11-05-2005, 11:15 PM Drop the pan, change the filter/ o ring. Its a very messy job, but still has to be done.. I switched to mobil1 synthetic.. It took about 8 quarts but this all depends on how long you let it drain.. 97cavalier 11-07-2005, 10:23 PM Drop the pan, change the filter/ o ring. Its a very messy job, but still has to be done.. I switched to mobil1 synthetic.. It took about 8 quarts but this all depends on how long you let it drain.. Is there still a filter and all the fluid in a 5speed 97? MT-2500 11-08-2005, 09:13 AM You did not tell them you had a 5 speed standard trans in your first post. But I gave you the instructions for the isuzu 5 speed in my upper post. MT-2500 colinlesser 11-08-2005, 09:25 AM i got one for ya, what is the black plug on the 2.2 ecotech 5 spd 2004 Squirrel221 12-17-2005, 08:45 PM Oh Boy vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
