Glue for resin kits?
MikeWz
11-04-2005, 04:02 PM
Will CA work to hold on a resin kit, or do I need to use epoxy?
MPWR
11-04-2005, 04:18 PM
CA will do fine. Shouldn't need epoxy.
Lambo003
11-04-2005, 04:38 PM
On either note . . . make sure the meeting joints have been roughed up then thoroughly cleaned.
Both CA and epoxy have been known to separate even after quite sometime due to a dirty/contaminated gluing surface. . .
RallyRaider
11-04-2005, 11:19 PM
Yes CA will do fine for most jobs. Epoxy has its uses on parts that require more fiddle factor. Don't forget other glues like PVA which is useful for small PE parts and such.
lotus_man
11-05-2005, 01:38 AM
It's also worth noting that small etch parts (emblems, body catches etc.) can be tuck down with clear paint. It's a technique I use quite alot on my 1:43 builds.
