did dealership mess up my truck?[RIT]IVIr_Evil 11-01-2005, 04:10 PM I had the dealership replace my driver side hub assembly in September and now I try to use All Wheel Drive or 4 wheel drive high/low nothing happens light just blinks. It worked befor they did this.. Did they mess something up? thanks -tom maxwedge 11-01-2005, 04:19 PM What year, auto transfer case?? [RIT]IVIr_Evil 11-01-2005, 04:36 PM it is a 1999 and yes it an automatic... maxwedge 11-01-2005, 07:04 PM Most likely not the the hubs are fool proof in this instance, a scan with the proper scanner will see whats what, sounds more like an electrical problem. GMMerlin 11-01-2005, 09:29 PM IVIr_Evil']I had the dealership replace my driver side hub assembly in September and now I try to use All Wheel Drive or 4 wheel drive high/low nothing happens light just blinks. It worked befor they did this.. Did they mess something up? thanks -tom Sounds like a "SINCEYA" problem. :lol2: Since ya worked on my vehicle, now something else doesn't work. Unless they replaced the left hub by removing everything on the right side of your truck, I doubt the hub replacement caused this. rlith 11-02-2005, 07:40 AM Since it's the right hub, check the vac cable going from the vac actuator under the battery tray to the vac switch on the transfer case. They may have knocked the hose off its retainer and the engine burned through causing a loss of vaccume. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
