Help
accord90
05-24-2002, 04:38 PM
Hey i was coming back from work the other night and my car started to do something strange started to pull or err push, anyway i didnt think anything of it because it went away after like 2 mins, then last night/morning 1 am the car started to do the samething but this time it didnt go away, then 5 mins later i found myself outside on the hwy with a car that couldnt run . IT has a new battery alternator clutch mastercylinder brakes rotors spark plug wires it has all its fluids, any suggestions to what may have caused my car to turn off and not wanna start . again it started to feel like the car was pulling or pushing then it just turned off. I have a 5 speed accord 90 ex btw.
b16a3sol
05-25-2002, 05:54 PM
i had the same problem when i had the exact same car, and never found a solution. the people at the dealership, who i got to know because of this very problem, could not figure it out either. replacing the main relay kept it from happening as often, but it still happened. check the ignition system as well, such as the cap, rotor, and ignition coil. getting those replaced also helped reduce the occurence of the problem. good luck finding the solution, and tell us when you do because i am curious.
