speaker amp
Google
Web AF
pottsy710
10-26-2005, 06:47 PM
I have a 97 gp gt with 70k miles, i have the eight speaker system, but i don't think it's bose, at least it doesn't say bose anywhere, and it doesn't say monsoon anywhere but it does have the 7 band eq that is typical of the monsoon setup, anyway, my rear 6 by 9's aren't receiving power and i had it tested and the guy said it was the amp that needed replaced. any ideas on where the amp is and where i can find one?
richtazz
10-27-2005, 09:30 AM
Give me the last 8 digits of your VIN number and I can tell you for sure if your car has the low-frequency external amp. Are you sure the rear speakers are getting no power, or do they intermittently work/not work? I had a similar problem with my 99, and it ended up being the rear speakers were faulty. I replaced them with some Pioneer 6x9's, using a $6 harness adaptor from Best Buy so I didn't have to cut my factory wiring.
pottsy710
10-27-2005, 09:42 PM
vf344149 are the last 8 digits of my vin, my fiancee works at circuit city so i had one of their road shop guys (who owns a gtp) check my speakers, he took the existing wiring to one of my 6x9's and hooked the wire up to a 6x9 he had in the shop he knew worked, and still no power, yes the problem is intermittent, but they usually do not work, occassionally after listening to the radio or a cd for awhile they'll kick on and stay on til i turn the stereo off. i just want to get all eight speakers working and it's a pain in the butt to modify this system because of all the adapters i need to get the steering wheel controls to work, and also if i replace the head unit i would lose my 12 disc in the trunk.
richtazz
10-28-2005, 05:16 PM
Your car does have the external amp, it should be in the dash behind and slightly above the radio. The GM part number is 16201332, but they are expensive. The Service ID code for the 8 speaker sound system with the external amp is UQ3 (found on the SPID label on the underside of the trunk), if you want to go boneyarding and know what to look for [the factory part is WAY espensive ($240)]
pottsy710
10-28-2005, 10:01 PM
will the bose amp work for my car? i found one on ebay for $40
richtazz
10-28-2005, 10:22 PM
Ask the seller what the part number is on the one he's selling, and post it here, I'll let you know.
BigBL87
10-30-2005, 01:52 AM
I had the same problem with my GT, although it only had the 6 speaker setup. My 6x9's would only work on occasion, and one was blown as it was. I just replaced them with some Pioneer 6x9's today and those are working like a charm. It may have just been a loose connection that would work on occasion, or it may have just been a problem with the speaker. Either way, simply replacing the speakers has solved the problem for me (not to mention I definitly have more bass now :biggrin: )
Oh, and I also have a head unit with the 7 band equalizer. I had the dealership replace the old one (with the basic equalizer) because the clock wouldnt work right. Didn't ask for it, just the one they happened to get. The clock still doesn't work quite right, but hey, now I have a better head unit at least.
pottsy710
10-30-2005, 06:47 PM
The part # is 10449848 according to the seller
pottsy710
10-30-2005, 07:17 PM
is my system a "monsoon" system, because there is no indication of monsoon on the head unit, i found a couple other amps on ebay for buick regal ls's, one's a concert II amp and one's a monsoon amp. will those work in a grand prix?
BigBL87
10-30-2005, 10:23 PM
as far as I know, there was never a monsoon system offered for the Grand Prix, at least 97-03 models. If you have a 8 speaker system, I'd assume you have the Bose system, but I could be wrong.
richtazz
10-31-2005, 10:58 AM
The amp he is selling is for an 02-03 model, and I don't believe it will fit your car.
pottsy710
10-31-2005, 02:44 PM
did they release a different external amp for every year of grand prix, and is the part number you gave me the only one that will work in my car?
richtazz
10-31-2005, 03:27 PM
According to the GM computer, 97, 98 and 99 are all different, and 00-01 are the same, and it doens't say if any are interchangeable. Normally , if a new number will work for an older number, GM will note the old number as being superceded. I know the 97 and 98 Keyless entry/security system is different and not interchangeable with the 99-up's, so it's entirely possible that the same is true with the external amps.
pottsy710
10-31-2005, 09:09 PM
sweet.... lol, stupid external amp, so basically i just have to find an external amp that exactly matches the part number you gave me, any idea if the regal used the same amp the gp does???
pottsy710
11-02-2005, 08:00 AM
well thanks for the help, i found an online store that will sell me a new one for forty dollars shipped. so i am in good shape. thanks again for your help, one last thing, do you have any idea where i can find a diagram of what to look for and how to take apart the dash to get to the amp?
BNaylor
11-02-2005, 10:50 AM
Just a suggestion but before you go tearing the dash apart try looking behind the passenger side of the dash behind the glovebox area for the Low Frequency Amp (LFA). You'll have to remove the passenger side lower kick panel. '97.5 - '03 GPs with the mid grade 8 speaker sound system have it located there.
Checkout old links below:
http://www.automotiveforums.com/vbulletin/showthread.php?t=444984&highlight=amplifier
http://www.automotiveforums.com/vbulletin/showthread.php?t=147328&highlight=amplifier
And if you need to do work with or replace the Head Unit here's another helpful link which also covers dash panel removal.
http://www.carstereohelp.com/stereoremovalPontiacGrandPrixSt2.htm
http://i5.photobucket.com/albums/y186/lizzywiz/gtp.jpg
Thrasher CAI, DHP v1.0 PCM, SLP Headers,
3.25 SC pulley, CAIT GMAF, 2.5 DP/Hi-Flow CAT,
u-bend delete, 160 TS, ZZP Stage 1 72mm TB,
TB spacer, MSD 8.5mm wires, Autolite 103,
Goodyear Gatorback Serp. & SC Belt,
Nitto NT555R Drag Radials
1/4 ET: 13.210 sec. @ 104.490 mph
0 - 60 ft: 1.945 sec.
richtazz
11-02-2005, 11:04 AM
The GM computer is very vague as to the location of the amp. I believe it is in the dash behind, but slightly above and to the drivers side of, the radio, but another illustraion shows it near the BCM, which is near the parking brake pedal on the drivers side.
BNaylor
11-02-2005, 11:41 AM
Out of curiousity Rich, what does your computer show for LFA location specifically for a '98, '99 and '00 GP?
richtazz
11-02-2005, 12:09 PM
It's kinda bizarre, if you look at the audio illustration, it shows it kinda half-ass behind the radio. If you look at the instrument panel illustration, it shows it down by the BCM.
pottsy710
11-03-2005, 09:51 PM
yeah, i found mine behind and slightly above the stereo on the drivers side, luckily my roommate's a certified car audio installer for infinity sound, so he replaced it for me for a case of beer lol. he's also the one who resoldered my hud.
Google
Web AF
