swapping in engine from a newer S-10BowtieS10 10-26-2005, 03:14 AM Tried doing a search, but could not find what I was looking for. :confused: I have a 95 S-10 with a 4 cylinder/manual transmission, and wanted to swap in a 4 cylinder/manual transmission from a 98+ S-10. Will it drop right in? Transmission? Switch engine harness? Wiring (OBD I ---> OBD II)? How much of a pain will it be? :banghead: Bads Crew 10-26-2005, 06:22 AM I;m gussing on this but I would think so if its the same size engine. I would hit an auto parts store and have them pull up the electrical parts for both years and see if they are the same. Im sure they didn't change the block castings or tranny mounts. rlith 10-26-2005, 08:26 AM You will need the following from the donor Engine harness Ecm Body harness BCM All needed sensors gauges et-al This is provided you are going to use the newer fuel delivery system If you want to retain your old FDS, then you simply need to swap over your old head and intake to the new block...(provided they are the same size block) vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
