Going to drive it off a CLIFF
tomogchi
10-24-2005, 04:15 PM
At this point, im am feed up with my vehicle running on only 4 cylnders. I have 6 cylnders, but what is the sense of using only freakin 4????????
1991 buick regal Custom, 3800 motor
Any ideas other than the ignition module (base plate) or the coil packs?
No spark for the third or sxith clynder. I know the ignition module isnt bad, I have tested it in another regal (same thing, cept a '92, works fine). Packs are fine also. There is no spark coming/going from 3/6 coil pack.
Should i be looking at the ecm? I have looked at the wiring harness that runs form the top half of the motor to the crank sensor, to the ignition module, to the back of the motor. There are NO cracks/ bumps/ irregularities minus for the dirty-ness of not being cleaned for 3 like years.
If i cant figure out what this problem is, i think i hear a derby or a cliff for this car. I have a little bit of cahs invested in this, and its pissing me off.
List of New parts
New Alternator
New heater core hoses
New fuel pump
New fuel Filter
NEw fuel lines
New fuel injectors
New baseplate (plus the cost of 2 from a junkyard, and the original)
New Harmonic Balancer
New Serpintine (sp?) Belt
New coil packs (+3 from a junkyard, plus the 3 orig.)
New brake calipers all around
New Brake lines all around
New Battery
And the list rolls on and on..
Please help befroe i force this thing to an early grave.
Bill
GTP Dad
10-24-2005, 04:38 PM
This sounds like two possible issues. 1 a bad wiring harness from the ecm to the ignition module or a bad ecm. Either will cause this issues and both may need to be replaced. I would try the ecm first since it is much easier to change than the wiring harness. One from a wrecking yard will be a good choice for money savings you may also want to purchase the wiring harness too since you may need it if the ecm doesn't solve the issue.
tomogchi
10-24-2005, 04:41 PM
Okay, Thanks Ill go grab them tommorow from a junk yard, and see if they work.
Thanks!
Bill
maxwedge
10-24-2005, 07:30 PM
Is this the same engine you were planning on modifying to 300 hp, did you attempt anything in that direction? This car came from a family member in good working order, how did you arrive at replacing that list of parts?
tomogchi
10-24-2005, 10:41 PM
The car did come from family, and i dont know how it all started. I think it most likely started because i started to race Civic's with little tips and stuff....
I swear, at 171,000 in change it all went wrong. Lmao.
All my modding money went into the car so far; and the only thing i actualy wound up getting for this was a intake for a '04 cavilier; that i have yet to install due to further problems...... And yes it was the same engine i was going to modify to 300 horse... But Modding does no good without a running vehicle. lol...
Bill
HotZ28
10-25-2005, 08:45 PM
I know the feeling of how it is to blow the doors off a civic in a Buick. I just had one last week (with 10K of mods), that tried to stay with my PAU, boy was he surprised!! Any car with 171K will need a lot of attention and parts to keep it winning.
Check the wiring harness from the ICM as it runs to the ECM, as suggested above, especially if it goes under the alternator. That area seems to be a wear point.
tomogchi
10-25-2005, 10:29 PM
Yeah.,... got an ecm and the harness the runs on the right hand side of the block (for the icm and etc.).....
No fix, But i did happen to notice something. at approx 2500+ rpms, i have spark in the 3/6 pack........ Now i am scratching my head.. wth am i missing?
Maybe a crank sensor or a cam sensor?
But god i lvoed the feeling of my 3800 rumbling past a fully modded civic... hehe, its great.......
Btw, not to sound retarted or anything, but what is a PAU?
Thanks,
Bill
GTP Dad
10-26-2005, 12:39 PM
With all the parts you have already replaced it won't hurt to replace the crank position sensor and the cam position sensor. The spark problem could certainly be related to either one.
HotZ28
10-26-2005, 07:34 PM
PAU = Park Avenue Ultra (supercharged with 2.2 drive pulley)
:cya:
tomogchi
10-26-2005, 07:48 PM
Hahaha, Sweet.
Im broke till friday now, But Ill probally go get both, and get it all done at once.
Thanks, and I'll let you guys know the turn out.
Bill
tomogchi
10-27-2005, 12:00 PM
.... I feel stupid..... I should have jsut said that i was going to get the crank sensor.
Oh well, lmao..
Thanks,
Bill
woopy
07-09-2006, 09:44 PM
Hello all,
i'm inhertiting, a 1991 buick regal don't know the engine size. It starts up fine and you can drive it, but then when you stop at a red light it stalls. after serveral atemps to start..... it finely starts but then it starts overheating. What is wrong with my car. Thanks all....
BNaylor
07-10-2006, 12:11 AM
Hello all,
Welcome to AF.
You would be better off starting a new post on your problem instead of resurrecting an old thread and boot strapping off it. Plus you may get better visbility. Also, be sure to get and post your engine size.
POSTING IN CLOSED OR OUTDATED THREADS:
If a thread has been closed, there is probably a logical reason for it. If you feel that the reason(s) for closure of the original thread are unjustified or wish further clarification feel free to contact any member of the moderating team. However, do not start a new thread about another closed thread.
Please avoid posting or voting in outdated threads. It merely clutters up the message board and makes it more difficult for fellow members to sort through the vast amount of information contained on the boards. If you have new and important information to add regarding a past discussion, feel free to start a new thread and if need be, add a link to the original thread.
