98 heat only works on high!!bill57 10-18-2005, 02:02 PM i have a 1998 ford f150 and the heta only blows out on high any ideas???? way2old 10-18-2005, 06:41 PM Check the blower resistor statler 10-24-2005, 03:56 PM I'm a little confused... Will the heat only come on if the switch is set to high, or it blows on high no matter where the switch is at? Also, you're referring to the temperature, and not the blower speed, right? bill57 10-24-2005, 04:11 PM I'm a little confused... Will the heat only come on if the switch is set to high, or it blows on high no matter where the switch is at? Also, you're referring to the temperature, and not the blower speed, right? figured it out blower resistor was fried! vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
