2003 Silverado Electrical Problem
Google
Web AF
aranwemj
10-13-2005, 11:03 PM
The battery in my Silverado was dead Wednesday morning. Jumped it and took it to Wal-mart to get it checked out. The put a new battery in it and checked the alternator. Everything checked out OK. Got in it this morning and it was DEAD again! Any ideas what could be draining this? I don't see any lights, etc. on. I'm stumped....
jers99z
10-13-2005, 11:42 PM
check for corrosion on the battery cables, constant draining usually indicates an electrical short somewhere, I still say start with the cables and look around them. good luck
GMMerlin
10-14-2005, 06:22 AM
If your vehicle is less than 3 years old and under 36000 miles all repairs are covered under your bumper to bumper factory warranty.
If your battery is going dead overnight, you have a componant that is powered up that is causing a draw on the system.
A parasitic load test on the electrical system will have to be performed to determine what is causing the draw.
Not true
jers99z
10-14-2005, 08:01 AM
notice the keywork "USUALLY" I work with electricity everyday, Im an electrician on some very expensive military aircraft, ive also been doing it for many years. It doesnt matter how old it is parts can still internally short causing a drain, all i was doing was giving a starting point, most common battery drains come from a faulty component, ie.. battery cables, alternator, starter solenoid etc etc..... the point im getting at sometimes you dont need to look that deep into things to find a simple problem. start small and inexpensive.
Google
Web AF
