tranny whine 96 ram 1500
softailFXST2004
10-13-2005, 08:14 PM
My ram 96 1500...the tranny is making a whineing noise lately. seems to be getting louder as time goes on what could this be...will a trans tune up help stop this or is the tranny going? it prob started a month or so after towing a trailer with a few harleys to bike week and back...like 1000 miles each way... any thoughts?
thanks!!
thanks!!
softailFXST2004
10-14-2005, 11:08 PM
come on guys some one HELPPPPPP!!!!! is the tranny going????
troy1
10-15-2005, 11:12 AM
its more than likely the torque converter is going out. does the sound change as you go through the gears or does it just stay the same? also what does the fuild look like (red black dark) make sure its full you have to check it in neutral. And one more thing make sure its not a alternator wine or anything else before you condem the trans
softailFXST2004
10-16-2005, 12:05 AM
You can hear the tranny whining differently through the gears like it gets louder as the rpm go up. and at some speeds it goes away some speeds it gets louder...its really loud at 50 but less at 60. thanks for the help...if its the tourque converter does that mean the tranny is shot?
neon_rt
10-17-2005, 01:24 PM
It could also be the front pump.... The front pump usually fails when the Torque Converter starts coming apart and sending metal shaving through the pump. You may want to drop the pan and check for metal shavings in the fluid. If you do have, you will need a total rebuild to fix it.
