2000 Chevy cav brake lights and blinkers out..Spazfishy 10-11-2005, 05:28 PM Hi I have a 2000 Chevy Cav 4 cylinder car. The problem that i am having is that my brake lights and blinkers no longer work. The running lights work fine.. I have already checked all the fuses and the light bulbs and there are no problems there.. What would be the recomended next step? Thank you in advance.. lilrogue78 10-14-2005, 07:10 PM get a test light and run you clamp to a positive connection then test the ground connections if that comes back ok then hook the clamp to a good ground connection then turn on either blinkers and test both tabs in the bulb socket vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
