96 CIVIC DX FUEL SYSTEM suggestions?
atariz81988
10-10-2005, 10:30 PM
I have a 1996 civic dx sohc engine and i am wanting to redo the whole fuel system. i would like to know what brands or parts work good for my car. if anyone has any suggestions as to what fuel rail , fuel pump, fuel pressure regulator, fuel injectors, etc. please help me out. thanks
Ace$nyper
10-10-2005, 10:31 PM
how much HP are you looking at?
atariz81988
10-10-2005, 10:49 PM
I have a 1996 civic dx sohc engine and i am wanting to redo the whole fuel system. i would like to know what brands or parts work good for my car. if anyone has any suggestions as to what fuel rail , fuel pump, fuel pressure regulator, fuel injectors, etc. please help me out. thanks im going to be using a stock sohc 1.6l engine and doing the whole fuel system, intake manifold/intake, 68 mm throttle body, cam gear, pulleys, head rebuild, and eventually maybe a turbo, it allready has a greddy style catback exhaust and a obx header running with no cat. dont know as to how much hp but my guess without turbo would be around 170 or so. any suggestions would help so much thanks
Ace$nyper
10-10-2005, 10:51 PM
get a cat and run it damnit.
that would be able to run off a stock setup save FPR.
atariz81988
10-10-2005, 10:54 PM
i dont understand what your saying. do you have any suggestions as to what parts i should get for my fuel system? i allready have a full cat exhaust and header
Ace$nyper
10-10-2005, 10:58 PM
you just said your going to run catless keep your cat on.
and you only will need an FPR anything else is a waste
atariz81988
10-10-2005, 11:02 PM
yeah the exhaust came with only a muffler and a resignator so i dont have a cat on it. but why would it be a waste to do any other fuel system mods?? keeping in mind all the other work im doing. thanks again for the help
superbluecivicsi
10-10-2005, 11:04 PM
you need some serious researching.
atariz81988
10-10-2005, 11:08 PM
yeah i looked up and found a couple of parts i wanted. i like the 255 lph walbro pump the aem fuel rail the aem fpr and i wasnt sure what size fuel injectors to buy. i really want to do my fuel system because it seems there isnt much else to do. I'm also going to be getting a msd ignition for it if that makes any difference.
superbluecivicsi
10-10-2005, 11:20 PM
if your not making major power, its not time to upgrade the fuel system yet ;) the oem rail and fpr are awesome.
atariz81988
10-11-2005, 11:23 AM
will my engine run right with just a fpr and fuel rail though?? i thought that if you just did one or two fuel components it would run a little off.
Ace$nyper
10-11-2005, 01:44 PM
nope you'll be fine.
