CHECK engine light...p1337 Help.~supadluxx 10-10-2005, 03:24 PM Did a sensor check, problem 1336 and 1337, crankshaft speed fluctuation sensor problems. Any idea how and where to get these fixed? jtrolinger 10-10-2005, 07:27 PM do it urself..lift ur car..prob. just the Cat Senor or something..check Intake too.. superbluecivicsi 10-11-2005, 06:06 PM do it urself..lift ur car..prob. just the Cat Senor or something..check Intake too.. save your bad advice for a forum like clubcivic.com anyways. P1336 - Crankshaft Speed Fluctuation Sensor Intermittant Interruption P1337- Crankshaft Speed Fluctuation Sensor No Signal check the the ckf sensor for resistance between the two teminals. if they are not within specs (i forgot what they were so your going to have to find that out yourself) replace the ckf sensor. also, independently check each terminal of the ckf sensor for contiuity to a ground source. there should be no contiuty. if there is, you a have a shorted wire somewhere. also check for continuity to the ecu, if you dont have continuity, there is an open in the wires somewhere. specs and pin locations on the ecu can be found here. http://forums.clubsi.com/showflat.php?Cat=0&Number=5045087&an=0&page=0 vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
