Removing radio bezel onn '98
Google
Web AF
lenjack
10-08-2005, 12:08 PM
Does anyone know how to remove the radio bezel without cracking or breaking it? I already know how to do it with breaking it. Thanks
Mike Gerber
10-08-2005, 04:45 PM
Remove the ashtray. Then pull from the bottom of the panel near the outside edges. It should come right off at the bottom. Then work your way up the sides until you feel where the the other 2 clips are and pull outward near the clips. You can use a dental pic to help locate and pull the last 2 clips. It also helps if the car is nice and warm inside so the plastic is less brittle. Once it is free, remove any electrical connectors from the backside.
Mike
lenjack
10-08-2005, 08:06 PM
Thanks Mike. In the past I've broken 2 of these, but if I recall , I started at the top. Dental pick you say? Being a dentist ,(really), I might find 1 or 2 lying around. :lol:
Mike Gerber
10-09-2005, 09:56 AM
Glad I could help. How much were the pieces to replace?
Mike
lenjack
10-09-2005, 10:11 AM
$28 dealer, $15 eBay.
lenjack
10-09-2005, 07:58 PM
Slow an easy from the bottom worked fine. I did use a dental explorer.
Mike Gerber
10-10-2005, 03:29 PM
Glad it worked out for you.
Mike
Google
Web AF
