2000 camry LE DRL?B_avrge 10-08-2005, 01:07 AM Ok I know I'm supposed to remove pin #10 but can anybody tell me what color it is, or provide me with the pinout chart? TIA don24mac 10-09-2005, 05:04 PM I have the 2000 Camry Repair Manual in front of me. Looking at the DRL Relay from the wire harness side the terminals are as follows: 11-10-9-8-7 Gap 6-5-4-3-2-1 25-24-23-22-21-19-18-17-16-15-14-13-12 (12 is adjacent to 1) (25 is adjacent to 11) When I disconnected the DRL on my 2000 Camry, I found which wire it was and cut it, and connected a wire to each end and put a switch in the panel right next to the aux power adapter, just above the front of the center console. (below the ashtray) I've found I use the DRL most of the time, but I do like having the ability to turn them off. B_avrge 10-09-2005, 11:49 PM I have the 2000 Camry Repair Manual in front of me. Looking at the DRL Relay from the wire harness side the terminals are as follows: 11-10-9-8-7 Gap 6-5-4-3-2-1 25-24-23-22-21-19-18-17-16-15-14-13-12 (12 is adjacent to 1) (25 is adjacent to 11) When I disconnected the DRL on my 2000 Camry, I found which wire it was and cut it, and connected a wire to each end and put a switch in the panel right next to the aux power adapter, just above the front of the center console. (below the ashtray) I've found I use the DRL most of the time, but I do like having the ability to turn them off. Thanks, I'll probably run a switch too but not sure yet. Can you Please do one more thing? Can you give me the color code of the wire, I just want to make sure 100% it's #10. Thanks again B_avrge 10-16-2005, 08:46 PM anyone have the wire color for wire #10? B_avrge 11-17-2005, 06:03 AM anyone have the wire color for wire #10? Please :smile: B_avrge 03-14-2006, 09:24 AM I Still need to know the color. Anyone? vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
