Rough Idle; Trouble w/ constant speed > 50
Google
Web AF
bmr909
10-03-2005, 09:17 PM
94 Beretta has rough idle and can not maintain constant speed above 50 w/o shaking. Service engine soon light not on and OBDI scan resulted in 0 results leading to conclusion that O2 sensor okay. Convertor not rattling and changed fuel filter. Any suggestions on what may be wrong?
bmr909
10-03-2005, 09:28 PM
Almost forgot...checked plugs...theyre okay. This is the 3rd time in 2 years this problem has occured. Other two times, went away instantly after period of 7-10 days
Britty05
11-13-2005, 02:40 PM
my mom has a 94 beretta Z26 and it does the same exact thing.. she doesnt no whats wrong with it either.. if i new i wish i could help ya!
jsgold
11-13-2005, 07:16 PM
Sounds like a weak or dead cylinder caused by a bad/weak plug, plug wire, coil pack, etc. A 4 cyl will shake like the devil with a fouled plug and a 6 cylinder will not do much better, especially at higher speeds. Had this with my son's Corsica, was a problem with a plug wire that would short on occasion, and the other son's Explorer did this twice with plugs that became fouled. A tune up would be in order to rule out coil pack(s).
Google
Web AF
