Noisy diffKlonkie 10-02-2005, 10:57 PM I've got a 1.6 5 sp Polo hatch, November 1998 model. There is a continuous "rumble" from the region of the diff or front wheel bearings. At first suspecting the wheel bearings I replaced these. No difference. A month later the rumbling has increased and appears to coming from the diff housing in all forward gears only. There is not excessive play on the dive shafts, beside the normal (and expected) diff backlash. The car has done only 62,000 km. Has anyone had or heard of a similar complaint? cheers Klonkie Melbourne, Australia Fanie 10-03-2005, 02:18 PM Does it get worse under acceleration or when you turn? Also have you checked the cv boots? Klonkie 10-03-2005, 06:35 PM The rumble increases with road speed only. Hard or mild acceleration does not change the pitch. CV boots OK, no grease leaking, CV joints feel OK. In reverse (with the car on stands) the noise is less, but I can't tell if the rumble is there as (a) can't go fast enough in reverse and (b) reverse gear is very noisy anyway. I have also noticed a tinkling noise in the diff that sounds as though there is a small part or a ball bearing tumbling around all by itself. Klonkie 10-03-2005, 06:36 PM The rumble increases with road speed only. Hard or mild acceleration does not change the pitch. CV boots OK, no grease leaking, CV joints feel OK. In reverse (with the car on stands) the noise is less, but I can't tell if the rumble is there as (a) can't go fast enough in reverse and (b) reverse gear is very noisy anyway. I have also noticed a tinkling noise in the diff that sounds as though there is a small part or a ball bearing tumbling around all by itself. Fanie 10-04-2005, 04:02 AM Have you checked the oil level of the gearbox? I had i similar problem on my polo and it ended up being a bearing inside the gearbox that went. Klonkie 10-06-2005, 01:35 AM The gearbox oil level is OK. I took it to an independent repairer yesterday and he suspects a damaged wheel bearing (one that I replaced). He is going to strip it next week so I'll know by then. cheers Klonkie Klonkie 10-16-2005, 06:37 PM It turned out to be the RF wheel bearing - dry as a bone. Hoe gaan dit in die ou Kaap, meneer? cheers John Fanie 10-17-2005, 02:40 AM It turned out to be the RF wheel bearing - dry as a bone. Hoe gaan dit in die ou Kaap, meneer? cheers John Goed en nat (jy weet mos hulle se die Kaap is soos n kleintjie as hy nie nat is nie het hy 'n wind) I thought you said you replaced the front wheel bearings? Enjoy Aus Fanie Klonkie 10-17-2005, 03:02 AM Turns out that the RHS bearing had very little grease in it. It was showing signs of overheating when we removed it after a few kms. The supplier has agreed to a refund. Pity that Province missed a place in the Currie Cup finals. We're hoping they show the finals live here on Saturday. Go Bulls! (my wife's hometown) cheers John Fanie 10-17-2005, 07:24 AM I see I'm originally from Bloem so I'm quite happy at the moment :grinno: Cheers Fanie smithjohnson 12-12-2007, 02:26 AM learning here.. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
