headlamps stay on
mmiller214
10-01-2005, 06:55 PM
I have a 99 gmc jimmy 4 wheel drive with 79000 miles. I just replaced the alternator and battery two days ago. I had noticed that my alternator gauge was fluctuating slightly around 14 at idle with no accessories on. Today for some reason my headlamps now stay one as if I left my lights on after turning the truck off. I have to disconnect my battery to shut the lights off. Tail lamps as well are on. Is this related to the alternator or what could this possibly be?
Thanks,
Thanks,
rlith
10-02-2005, 06:58 AM
Do the lights stay on when the car is turned off? If so I doubt its the alt, it's more likely a relay.
mmiller214
10-02-2005, 09:08 AM
Yes the headlamps stay on when the car is off. I have to disconnect the battery to avoid draining it. Relay? Where would it be under dash or hood? I have a Chiltons manual but they are vague. Thanks
ChrisGood
10-02-2005, 11:10 AM
the headlight relays are normally located in the fuse panel, there is one under the hood and one in the car, cant remember which has it.
rlith
10-03-2005, 06:25 AM
Actually, it may be your switch (thought about this a little more) A good way to test is simply remove the plug off of the back of the light switch and see if it goes out then (also disconnect the dimmer switch) If your lights go out you've found the culprit. As to where the relay for the lights are, I'm gonna have to check my diagrams... Been a while since I've had to look it up.
rlith
10-04-2005, 06:46 AM
Any luck?
mmiller214
10-05-2005, 06:36 PM
Thanks for the help fellas. I did end up replacing the switch. I also replaced the relay and put the old one back after replacing the switch. Keep this one for the books!
Thanks!
Thanks!
rlith
10-05-2005, 08:39 PM
So in the end it was the switch? Cool..Glad you got it worked out.
