Help!!! 1994 LeSabre wont stay runing/hard starts
DEADMEAT101
09-29-2005, 09:00 PM
my friend has a 1994 LeSabre with the L27 3800 NA, it has a startin/runing problem. You turn the key and it cranks but wont start. you have to pump the petal like a carb and then it starts but you have to keep pumping it or it stalls. Also when you turn the key to accessories I dont hear the fuel pump prime/start. Im thinking it might be a cloged fuel filter or a bad fuel pump relay. Does anyone know where the fuel pump relay is? I know they are on the firewall but not sure what one is the fuel pump, any suggested would be great, thanks...
Malachias
09-30-2005, 03:13 AM
If you canīt hear the fuel pump working, I`m pretty sure that you have
a bad fuel pump. Will be fine to check your fuel filter too.
Good luck!!!!
Malachias
