Bleeding brakes on a Midgetjrm1963 09-28-2005, 03:30 PM I have a '77 Midget that needs some brake work completed. Because of a small leak, I have to periodically refill the master cylinder and bleed the brakes. The problem is, I haven't been able to locate the bleeder valves on the rear cylinders. My manual has perfect pictures on the front discs, but nothing on the rears. I thought I had enough mechanically ability to locate a small valve, but this one has me stumped. Any suggestions on where this should be located? CraigFL 09-28-2005, 03:49 PM I've bled many a wheel cylinder by cracking the tubing fitting to release the air (when the bleeder was broken off). jrm1963 10-04-2005, 05:01 PM Sounds too simple, sorry I didn't think of it myself. Thanks for the help. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
