Page updated on 06-24-2018
How do i remove the speakers in my 99 cougar?
MikeJacobs
09-28-2005, 12:58 PM
Can Someone help me?
I want to put some new speakers in my 99 mecury cougar but i dont no how to remove then from the panals, hwlp me please..
mikecox1
11-19-2005, 11:06 PM
calm down it is not that bad in the front the door panels have to come off. one screw behind the cougar symbol on the inside door handle one screw on the bottom front behind the plastic cap 2 or three torx screws in the door jam (where the door latches) remove theme and lift the door skin off .if need be remove window and door lock plugs dont worry if you take them both off you can't put them back on wrong there both different .for the rear open the door there is a small plastic cover in the jam pry it off there are two screws torx #20 i beleave remove them. pop the trunk right next to the seat latch ther are some more torx screws remove the ones needed to pull the panel back.you don't have to remove the panel all of the the way just pull it back enough to get to the speaker screws. you should know you will need to cut the plug and put new crimps on the wires to put aftermarket speakers in .all can be bought at raidoshack crimps require a crimping tool also at raidoshack for about 15 bucks ,buy it you will use it more if you plan on putting a sound system in your car or anyone elses
