Headlights
Google
Web AF
Tonyr
09-25-2005, 09:46 PM
As many others' cars, my headlights are pretty crappy. Filled with moisture and the front lenses are about to come off. Is there a place to order new ones at good prices made a lot better than they are now or are we stuck ordering more crappy ones?
Thanks for your help.
kita23
09-25-2005, 10:43 PM
Gmpartsdirect.com
pfyc.com
ebay.com
clubgp.com
Where ever. but shop round, sometimes you canf ind them on ebay for cheaper than the other and stil be new like mine.
regalfriend
09-26-2005, 11:17 PM
My car did the same thing...it seems the silicone sealer they used was pretty cheap...before i got new ones i tried to fix the one i had, and it worked...it was pretty easy to do........My car is 97 Regal....on the back of the headlight assembly there are to plastic retainers...slide them both up to remove the light unit...disconnect the wires...i then brought the whole unit in the house and was able to seperate the clear lense from the backing...i used a razor knife and a steak knife which had a bend on the end...after all of the old silicone was cleaned out i used a mix of windex and water, with lint free paper towells to clean both pieces...i used high heat gasket sealer and applied it to the main piece only( not the clear lense)...i reapplied the lense and used masking tape to hold it tight. and let it sit overnight...next day i replaced the headlight and has been good for 2 years and is still good....it would have been easier to just replace , but was sure any aftermarket or dealer parts would do the same thing again soon
Google
Web AF
