Whats the quickest and easiest EGR test?Rottweiler28 09-25-2005, 04:10 PM Just wondering what would be the easiest way to test EGR? Suggestions please. eldiablo1100 09-25-2005, 10:35 PM here's the way i test the EGR valve with the engine idling, disconnect the vacuum hose from the EGR valve and disconnect the vacuum hose to the fuel preasure regulator, put the vacuum hose to EGR valve. when the valve opens, the engine should stall to test the EGR solenoid, you need a scan tool if it's an electrical EGR valve, then you need a scan tool to test it Rottweiler28 09-26-2005, 05:33 AM here's the way i test the EGR valve with the engine idling, disconnect the vacuum hose from the EGR valve and disconnect the vacuum hose to the fuel preasure regulator, put the vacuum hose to EGR valve. when the valve opens, the engine should stall I disconnect both vacuum hoses while idling, then put the egr valve hose back on the egr? Or put the fuel pressure hose on the egr? I think its the egr hose back to the egr but I just want to be sure. to test the EGR solenoid, you need a scan tool if it's an electrical EGR valve, then you need a scan tool to test it How can you tell what type egr you have? If it helps this is a 91 plymouth voyager 3.0. Thanks for the reply, I will try this tonight after work. eldiablo1100 09-27-2005, 09:55 PM take both of them off, then take the hose you took off of the fuel preasure reguator and put it to the EGR valve. the hose from the fuel regulator should have about 22 PSI of vacuum. when you put it to the EGR valve, it will be enough vacuum to open the EGR valve and send some exhaust gases into your cylinders causing your engine to stall the 91 probablly has a regular EGR valve vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
